Gen VI Cam shaft in Mark IV block >
Old 07-16-2005 | 09:03 PM
QUIKDECISION's Avatar
Default Gen VI Cam shaft in Mark IV block
I am unclear re: Thrust bearing, Cam button, and distributor gear for the combination of of using gen VI ( HP-500 Cam in a Mark IV ( 365 magnum ) block. I am using the single roller chain ( stock Gen VI - I think ) cam gear and chain. So I believe that I need a cam button..
Do I also need the thrust bearing with the gen VI timing gear?
Do I have to change the distributor gear to bronze?
I believe that the HP-500 cam is a crane cam....
Darn it... I find this out after I installed my timing cover and glued it all up to the oil pan..... Geez...
Thanks very much for any help anyone can offer to clear this up for me...
Quikdecision
QUIKDECISION is offline
Old 07-17-2005 | 07:17 PM
Question Re: Gen VI Cam shaft in Mark IV block
Hey folks,
I'm just wondering, am I stuck using a cam button??
Thanks.
Old 07-17-2005 | 07:49 PM
Swede's Avatar
Default Re: Gen VI Cam shaft in Mark IV block
I run a gen VI block with a gen V timing cover with a cam button. You have to tap the block for the Gen V timing cover because it has 10 bolts instead of 6. I'm not sure how the cam button works with the gen VI cover. Talk to RMbuilder he will know.
Swede is offline
Old 07-17-2005 | 08:43 PM
Swede,
Thanks for the reply...
Old 07-17-2005 | 11:17 PM
wkd1's Avatar
i believe comp cmas makes button for this application
wkd1 is offline
blown formula
17
06-23-2023 09:31 AM
GNJ2
5
09-29-2004 08:25 AM
pacedog
6
07-06-2004 11:06 PM
DonMan
2
04-03-2004 11:51 PM
klmken
2
08-01-2003 09:25 PM
