cmi on 496's twin application ? >
Old 07-20-2005 | 11:56 AM
26sonic's Avatar
Default cmi on 496's twin application ?
adding the new cmi exhaust on a pair of 496ho's running already 75mph gps . what should I expect top speed would be if each engine would gain the reported 50-60 hp ?
26sonic is offline
Old 07-20-2005 | 12:23 PM
Default Re: cmi on 496's twin application ?
I Too Want To Know The Rusults I Have A 04 Sonic 31ss With Twin 496h0s
GRSFAST is offline
Old 07-20-2005 | 01:17 PM
dkwestern's Avatar
This add should put you at 485 horsepower a side (assuming 60 PSHP), so speeds should be that of 500EFI's or a touch faster, not considering torque, which I have no idea how they compare.
dkwestern is offline
Old 07-20-2005 | 08:23 PM
Question Re: cmi on 496's twin application ?
Post your boat length, your prop type and pitch,weight including gear and fuel, your final drive ratio, water you run in ,salt or fresh, your altitude where you boat mostly and I can use our calculator to refigure your boat speed. My guess would be about 4-5 mph but I am still a little suspect on these headers adding a real 60HP on a stock 496HO and ECM. Time will tell hope you get even better results!
Ray @ Raylar
Raylar is offline
Old 07-20-2005 | 08:28 PM
BUIZILLA's Avatar
instigator
I'm with Ray on this one myself.... I just can't see that 60hp claim as being realistic, no matter how good the battery's are in the calculator. That's a BIG claim to make.
Jim
BUIZILLA is offline
Old 07-20-2005 | 08:40 PM
mwdill's Avatar
Im waiting on the results too, would be nice to bolt on 60hp.
mwdill is offline
Old 07-20-2005 | 10:01 PM
Please post the results.... And what is the cost for each set?
csmall is offline
QWKRN U
Eliminator
11
08-21-2009 05:05 PM
Jupiter Sunsation
Cigarette
20
01-16-2008 01:21 PM
cherrycobalt262
03-13-2006 01:38 PM
wrinkleface
12-23-2005 01:53 AM
Here's Johnny
Sunsation
4
10-30-2002 11:10 AM
