any riggers care to give some FREE advice? >
Old 07-21-2005 | 08:29 PM
ratman's Avatar
Default any riggers care to give some FREE advice?
need some help. i have a clearance issue between my two center pipes and need a fix and any suggestions would be too kind. thx, ratman
ratman is offline
Old 07-21-2005 | 10:52 PM
Mr Gadgets's Avatar
Charter Member #601
Default Re: any riggers care to give some FREE advice?
ratman... at what point do they touch.. Could you tip the top in and gain clearance or is it right at the bend in the tubes? If you made a wedge you could tip them in some.. That might help?? How about a pic with the two side by side.
Mr Gadgets is offline
Old 07-21-2005 | 11:14 PM
If they're touching at the tops, maybe you could get some 3/4 " exhaust header/manifold spacers from CP Performance and angle-mill them and install them on one or both of the center headers so they kick the tops outward away from each other?
HARDCORE A/O is offline
Old 07-22-2005 | 01:13 AM
HiPerf2000's Avatar
it all depends where the clearence issue is......bottom or top ????
Like mentioned above, if the problem is high, you maybe able to space out the bottoms.
HiPerf2000 is offline
jmeng
04-15-2008 09:31 PM
scarabrick
01-16-2002 02:20 PM
