Prop help.
Old 07-25-2005 | 09:24 PM
gripit's Avatar
Default Prop Selection Cig Bullet
Found these numbers on the prop. HC CL 22 L QIV & HC CL 22R QIV. They are 4 blade stainless steel. What brand are they? They are on an 88 Cig Bullet.
gripit is offline
Old 07-26-2005 | 06:47 AM
throttleup's Avatar
Default Re: Prop help.
Those are Hydromotive Quad IV props, 22" pitch, right and left.
Matt
throttleup is offline
Old 07-26-2005 | 08:28 AM
gripit's Avatar
Default Re: Prop help Cig Bullet
If I wanted to upgrade, what would be your reccomendations.
gripit is offline
Old 07-26-2005 | 09:46 AM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Gripit,
Are those TRS drives you running in that Bullet? What rpm and speed are you getting with a light load on those props and at what rpm do you need to run your engine package w0t?
GoCiggie31 is offline
Old 07-26-2005 | 09:51 AM
gripit's Avatar
Originally Posted by GoCiggie31
Gripit,
Yes, they are TRS Drives. I'm getting about 60 mph with half fuel tanks. I have 420 HP's but don't know what rpm I need to run my engine at wot.
gripit is offline
Old 07-26-2005 | 10:03 AM
throttleup's Avatar
Can you tell me about your performance numbers.
What motors do you have?
What is your WOT RPM with the 22P QIV's?
What is your WOT MPH via GPS?
What is your gear ratio?
Julie
Old 07-26-2005 | 10:12 AM
GoCiggie31's Avatar
I hear the hp420 like 5200-5400 rpm range at WOT,
I would guess your gear ratio (unless changed is 1:5) what rpms do you run at wide open throttle when you have those hydros installed?
Old 07-26-2005 | 10:22 AM
gripit's Avatar
I'm not sure the RPMs, I will have to wait for the weekend. The 5200-5400 range sounds right for the HP 420's.
gripit is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
