Drilling Stringers >
Drilling Stringers
Drilling Stringers
Old 08-02-2005 | 08:40 AM
pachangalpina's Avatar
Default Drilling Stringers
I have done a search an could not find the info I needed, but I need to know how everybody treats the holes drilled into the stringers. I am installing strainers and will have one on either side of the main stringer and they will be thru bolted. Do I just seal the holes with silicone?
pachangalpina is offline
Old 08-02-2005 | 09:05 AM
HiPerf2000's Avatar
Default Re: Drilling Stringers
you should use white 5200. Or if you plan on taking the braket off anytime soon, 4200 is more forgiving upon removal.
HiPerf2000 is offline
Old 08-02-2005 | 09:25 AM
Chris288's Avatar
After drilling I would coat the inside of the holes with EXPOXY !!
Chris288 is offline
Old 08-02-2005 | 09:35 AM
Indy's Avatar
Member #154
That's what I do also.
Indy is offline
Old 08-02-2005 | 07:40 PM
Pwrbt33's Avatar
Talking Re: Drilling Stringers
We use West system. Two or three good coats and she'll be like new.
John
Pwrbt33 is offline
Old 08-02-2005 | 08:28 PM
ratman's Avatar
don't forget to drill the holes oversized if you are going to treat them with epoxy, as it will shrink the hole. my fathers has had boats for 45 years and he always uses 5200 liberally coated on any bolt or screw that goes into transum stringers etc. never seen a rot problem on any of his boats. be sure to goop it up good and use a rag with some laquer thinners to clean up.
ratman is offline
Old 08-03-2005 | 10:40 AM
batty
Excalibur
5
05-14-2011 08:21 PM
bigboat28
2
03-04-2008 07:29 PM
US1 Fountain
Baja
5
07-19-2007 03:32 PM
IHTFP
Detailing, Painting, & Fiberglass
12
04-22-2006 12:01 PM
tanned fat looks better
07-28-2003 06:54 PM
