arneson drive
Old 08-04-2005 | 05:13 PM
Default arneson drive
anyone know how much the bravo to arneson conversion kits that bolt up cost? any experience with them?
sd11856g is offline
Old 08-04-2005 | 05:27 PM
Lofty's Avatar
Default Re: arneson drive
I think they run about $16k on up per side. Call Rik, he's on the board and I'm sure if he's not budy chasing some tail he'll pick this up.
http://www.arneson-industries.com/
Arneson Ind
San Rafael Ca
415.485.0788
Lofty is offline
Old 08-05-2005 | 12:30 AM
Mark in So. MD's Avatar
Below is exactly what Rik emailed me when I was inquiring about the same thing, note though, this was in Nov. 2002. I ended up selling first so I never got to do the conversion.
The Arneson does not require any of the parts from the Bravo. The ASD6/Bravo Conversion kit will give you everything that you need to use the Arneson on the boat. Our standoff box will cover the cutout of the Bravo eliminating the need to re-glass the transom.
The ASD6 Bravo Conversion Kit includes the following:
Char-Lynn Hydraulic Helm Unit
Gil HD Rear Engine Mount
HD Drive Plate
HD Bellhousing
New Modified Velvet Drive Transmission 900 HP rating.
Drive Line
Arneson Standoff Box
Arneson ASD6 Drop Box Drive Unit:
Complete with External Hydraulic Steering and Trim Cylinders, Trim Pump,
Mounting Bolts, External Hydraulic Hoses, Trim Pump and Mounting
Instructions/Drill Template.
The ASD6 Drive Unit and the transmission come with a one year warranty in approved applications.
Options: HD Gear Upgrade: $900.00
Transmission Upgrade: $400.00
List $15,500.00 ea. F.O.B. San Rafael, CA USA
Thank you,
Rik Wimp
Arneson Industries
Mark in So. MD is offline
Old 08-05-2005 | 01:42 AM
Rik's Avatar
Rik
Offshoreonly Advertiser
What info do you need?
Take a look at this thread http://www.offshoreonly.com/forums/s...d.php?t=108728
What boat/power do you have?
Rik is offline
Old 08-05-2005 | 01:44 AM
DirtyMoney's Avatar
Rik how about listing some of the performane increases with various hull designs so everybody can understand that you get reliability with performance and lower cost new over most setups.
DirtyMoney is offline
BAJA WILL
11-28-2006 08:36 PM
Byron
07-17-2003 05:29 PM
sutphen412
4
07-16-2003 06:46 AM
Jassman
07-05-2003 03:11 PM
sutphen412
06-30-2003 08:59 AM
