496 oil in coolant >
496 oil in coolant
496 oil in coolant
Old 08-08-2005 | 12:09 AM
betitbig's Avatar
Default 496 oil in coolant
I have a 496mag HO whippled, with less than 10 hours on it and I keep getting oil in the coolant. I have no reverse problem such as coolant or water in the oil. I have pressure tested the coolant system for any leaks and only loose 2lbs of pressure in an hour, so what gives?
Anyone ever have this problem or hear of it?
Any ideas on what would cause this to happen?
betitbig is offline
Old 08-08-2005 | 12:46 PM
betitbig's Avatar
Default Re: 496 oil in coolant
Could it be a problem with the heat exchanger?
betitbig is offline
Old 08-08-2005 | 01:48 PM
betitbig's Avatar
Or could it be a problem with the oil cooler?
betitbig is offline
Old 08-08-2005 | 04:49 PM
Hydrocruiser's Avatar
Arrow Re: 496 oil in coolant
Are you getting coolant in the oil?
Even small amounts can destroy the engine.
Time to send an oil sample to Blackstone Labs.
Hydrocruiser is offline
Old 08-08-2005 | 06:15 PM
GOODT's Avatar
Sounds Like A Head Gasket
GOODT is offline
Old 08-08-2005 | 06:50 PM
Pwrbt33's Avatar
Talking Re: 496 oil in coolant
Ditto on the head gasket.
Pwrbt33 is offline
Old 08-12-2005 | 01:29 AM
Kokopelli's Avatar
Steve,
Don't think it its the heat exchanger or oil cooler - I beleive both are cooled by sea/lake water not coolant. I too would lean towards head gasket - Were the heads torqued correctly? Their is a very specific procedure to torquing the 496 heads I beleive. Check with Peto or GT. You don't want coolant in your oil, it's bad news.
Kokopelli is offline
Old 08-12-2005 | 07:45 PM
crayolacrazy's Avatar
I noticed my coolant bottle getting dark after getting it real hot .In my case its sut. I removed the tank cleaned it 5weeks ago now I have to do the other side I hope you have the same issue.I also run 496 s with whipples call me at 412 7810881
crayolacrazy is offline
fountainfevr
8
06-05-2008 11:07 AM
betitbig
9
02-21-2007 12:16 PM
betitbig
4
02-05-2007 08:17 PM
Harper220
29
05-31-2005 04:51 PM
Harper220
1
08-02-2004 06:13 PM
