Weird igntion problem >
Old 08-10-2005 | 07:54 AM
Default Weird igntion problem
I installed a new electronic distributors.(mallory). Port motor had a miss, two cylinders were firing intermittenly. Changed plugs and wires, no help. Swapped distibutor to starboard and the problem is there now. I could remove the #1 and #6 plug wires and rpm doesnt drop. I put the old points distributor in and same thing. I get a good blue spark at the plug end of the wire and from the cap as it jumps to my test light. The only thing that I can think of it being a problem with the cap. Thats the only thing I havent swapped. It is a new cap that came with the new distributor. Could a cap cause this? There is no moisture in it and no signs of carbon tracking. Plugs are all new and so are the wires. I alos swapped coils with no help. WTF, this is driving me nuts
MILD THUNDER is offline
Old 08-10-2005 | 07:55 AM
Default Re: Weird igntion problem
When I put the timing light on #1 it flashes erratic and kind of slow, but if i put it on #2 wire it flashes very steady and fast.
Old 08-10-2005 | 08:33 AM
GOODT's Avatar
Yes it could be the cap try swapping it with the othe motor
GOODT is offline
Old 11-18-2005 | 05:58 AM
What ever happened with this problem? I am having something similar with basically the same engines except thunderbolt IV distributor / ign.
stinger390 is offline
Old 11-22-2005 | 07:32 PM
Bad cap.
Old 11-22-2005 | 08:16 PM
Reed Jensen's Avatar
Could be a bad rotor too......
Reed Jensen is offline
JohnnyTampa
13
07-10-2007 01:04 AM
MadMat
9
07-03-2006 11:50 AM
plumbers crack
9
09-14-2005 09:31 PM
Magicfloat
10-18-2003 04:54 PM
Sandahl
7
09-25-2003 05:38 PM
