Oil Temp Problem >
Oil Temp Problem
Oil Temp Problem
Old 08-17-2005 | 09:24 AM
lakeluvr's Avatar
www.sunriseuph.com
Default Oil Temp Problem
I feel that I am running excessive oil temps. Just cruising around 3K will drive them up to over 270, I then drop back to 2500rpm and they cool back down, but usually stay around 230. It has been speculated that I have the original smaller oil coolers that came the the 454s. Not that I am running 502s they might be too small.
Any thoughts on this??? And if they need replacing where to get some???
Thanks for the help.
John
lakeluvr is offline
Old 08-17-2005 | 09:35 AM
Default Re: Oil Temp Problem
Did this just start after you changed to 502's. What temps did the original engines run. I have the standard cooler and it peaks at 240 degrees when I spin it above 4,500 RPMs.
1BIGJIM is offline
Old 08-17-2005 | 09:45 AM
Wobble's Avatar
SORE MEMBER
John
try this thread for some good info on the basics. 270* @ 3K seems like way too much.
http://www.offshoreonly.com/forums/s...3&page=1&pp=20
Wobble is offline
Old 08-17-2005 | 10:09 AM
lakeluvr's Avatar
www.sunriseuph.com
These motors were in the boat when I bought it, so don't know about before.
Also, I had to freshen one up last year because of a problem and its temp is within a few degrees of the other one with more time on it.
Thanks again.
John
lakeluvr is offline
Old 08-17-2005 | 10:41 AM
articfriends's Avatar
You beat me to it!!
articfriends is offline
Old 08-17-2005 | 10:45 AM
Wobble's Avatar
SORE MEMBER
Originally Posted by articfriends
You beat me to it!!
3rd cup of coffee
Wobble is offline
Old 08-17-2005 | 11:00 AM
3rd cup of coffee
I'm home playing hookey from work today so that i can get some transmission jobs done to pay for this damn 3.00$ gas!!!Smitty
Old 08-17-2005 | 12:07 PM
lakeluvr's Avatar
www.sunriseuph.com
Excellent article, thanks so much. I hadn't seen that one before. Great info.
And thanks Smitty for enlightening all of us. Great job.
John
lakeluvr is offline
Velocity Vector
0
04-03-2008 01:45 PM
MarkDonzi
16
06-07-2006 04:05 PM
rbratcher
Fountain
6
08-08-2005 08:01 PM
29scarab
2
07-03-2003 03:53 PM
powerguy
5
08-04-2002 07:44 PM
