Cam Expert Needed
What cam would you run in this engine?
Gen VI 454, bored .030", 4.25" stroke, 6.385" rod, (489 cubic inches ), 10.0 : 1 compression, Merlin VR square-port heads, Strip Dominator intake, 800 Holley DP, full MSD ignition, Stainless Marine Gen III exhaust. This runs a factory style roller. I am currently running a Crane 731. I have the engine apart right now and would like to bump it up. I was running 8.5 compression, but bought new pistons. Reversion is not an issue, the exhaust is dry up to the tip.
Should I keep my current cam?
What do you guys suggest?
I can have a custom-grind made also....
Originally Posted by rmbuilder
HigherPower,
Where will you prop for peak power/max WOT? Target HP?
Bob
Bob
I would like to get about 550 hp out of this combination.
Thank you for your response. The MAIN reason I am a member here is because of the excellent technical discussion.
Higherpower,
Those heads have very strong low/mid lift flow characteristics. The runner size/CSA will also provide good velocity for this displacement. Your target of 550 HP brings you in @ 1.13 HP/CID which would be no problem with a cam change. I would closely watch timing and octane and determine the exact compression ratio with the new components.
Bob
Bob
Originally Posted by HigherPower
So...... what kind of specs do you suggest?
Can you grind one?
Can you grind one?
Hey you want to sell that 731? If so PM me the $$...
Patrick
Patrick
Originally Posted by Pat McPherson
Crane 741 or Custom Grind...
Originally Posted by Prowler
the new 741 falls off at 5500 rpm's now and the 731 falls off at 5200 rpm's trust me i know.so now it's time for another cam change.
Yes, I would agree that the 731 is good to about 5200 in a 502...
Patrick
Patrick
