Exhaust questions
Old 09-10-2005 | 12:00 AM
Default Exhaust questions
I have a 540 inch bbc thats mild,nice heads, 8.8 to 1 comp, 570 lift hyd roller and a single 1050 holley. Right now I am running an eddie marine EMI thunder exhaust. I have heard these are not very good but am I going to get a noticeable gain by changing them. If so which ones do you think would be the best?
havasu fun is offline
Old 09-10-2005 | 07:02 AM
Vinny P's Avatar
I hate the winter!!
Default Re: Exhaust questions
I have a simliar enigne. I built a n.a. 540, makes 680 hp. All good parts, AFR heads, 9.25 compression, .600 lift 238* cam, etc. etc.. Anyway, I originally had Gil WetOffshore exhaust on my 454 Magnum. I put that exhaust on this 540. I ended up with a bad reversion problem. The end result was switching to full dry CMI headers. Problem was solved but gained no noticable speed. Maybe 50 rpm, nothing major.
Vinny P is offline
Old 09-10-2005 | 07:26 AM
You may want to look into Lightning headers, I put a set on my 25 checkmate back in 90 454 with a roots supercharger made a huge performance gain, but becareful you should check the plugs!! will most likly have to go up a jet size or two!!!!!! I have run them on every motor since then, got them on my cat now with 738 HP NA motors.
abones is offline
Old 09-10-2005 | 07:57 AM
Are you located in havasu?? just asking because we have a place in havasu and boat there a few times a year. we live in Michigan (for now) it sure is nice out there!!
abones is offline
Old 09-10-2005 | 08:12 AM
GOODT's Avatar
CMI IS THE BEST IVE SEEN , I do have a couple of set that are used if interested email me or give me a call
GOODT is offline
Old 09-10-2005 | 11:35 AM
LIOPA's Avatar
YUP......... go CMI
LIOPA is offline
Full Force
17
10-23-2007 09:11 AM
betitbig
6
01-28-2007 11:09 PM
MILD THUNDER
2
01-10-2006 09:23 AM
CC247
5
04-14-2005 03:26 PM
runnin gun
Fountain
12
12-09-2004 09:11 AM
