Trim tab limit switch... >
Old 09-13-2005 | 12:22 PM
Sydwayz's Avatar
Forum Regulator
Default Trim tab limit switch...
How do I adjust this? My drives come up and touch my swim platform when trimmed up. I know where the switches are on the gimble housing, but how do I adjust them?
Sydwayz is offline
Old 09-13-2005 | 12:49 PM
GOODT's Avatar
Default Re: Trim tab limit switch...
Hey Brian,
there really is no ajustment for the trailer side ie..total up
GOODT is offline
Old 09-13-2005 | 05:06 PM
They make spacers to go into the cylinders,
to prevent them from coming full up.
item # 27 is it.
http://www.mercruiserparts.com/Show_...YDRAULIC+HOSES
JaayTeee is offline
Old 09-13-2005 | 06:33 PM
GOODT's Avatar
jay t hate to bust your bubble but thats a zinc and if it were a spacer it would keep the drive from coming down not up sorry!!!!!
GOODT is offline
Old 09-13-2005 | 06:38 PM
GOODT's Avatar
Hey Brian
Did You Catch Your Pic In Poker Run Mag ????
GOODT is offline
Old 09-13-2005 | 07:21 PM
They do make a spacer for some drives that will hit the swim platform . I am not sure if your saying you have a bad switch or your drive goes too high. If its the latter you can ad a spacer (not zinks) but a spacer
ingveys is offline
Old 09-13-2005 | 07:45 PM
Mbam's Avatar
Offshoreonly Advertiser
Joe, Jay is right, that is the spacer, it just looks like the zinc. It goes inside the cylinder on top of the piston. It's slotted so all you have to do is remove the end cap and slip it in. YOu could also use more than 1 if needed. There are 2 in each kit.
Mbam is offline
Old 09-14-2005 | 07:59 AM
Thanks Marc.
Item # 6 is the Zinc annode.
JaayTeee is offline
Old 09-14-2005 | 11:25 AM
Sydwayz's Avatar
Forum Regulator
Thanks guys. I figured I could somehow adjust the switch to keep them from going up to far. I have the little rotary switches on each side of the gimble housing. I just don't know how to play/adjust them.
Sydwayz is offline
Old 09-14-2005 | 12:55 PM
GOODT's Avatar
Jay tee Im very sorry learn something new every day 25 yrs never saw those before!!!!!!
GOODT is offline
