2004 Dodge 1500 tow rating
Old 09-15-2005 | 12:22 PM
t500hps's Avatar
21 and 42 footers
Default 2004 Dodge 1500 tow rating
I may have to use a Dodge truck for a 30 mile haul (9-10K lbs).
1500 quad cab 4x4, 5.7 hemi w/ 20 inch wheels. Anyone know the ratings, or tow with this rig?
t500hps is offline
Old 09-15-2005 | 01:12 PM
Sean H's Avatar
A to Z
Default Re: 2004 Dodge 1500 tow rating
7400 or 8400 depending on what ratio you got...
you will be over the tow rating and the gcwr of the truck towing that much....
Sean H is offline
Old 09-15-2005 | 01:49 PM
t500hps's Avatar
21 and 42 footers
Originally Posted by Sean H
................you will be over the tow rating and the gcwr of the truck towing that much....
thanks but I figured I'd be over. I'm just curious if it will have significant problems. The trailer pulls well and has triple Disk brakes so stopping shouldn't be too bad.
t500hps is offline
Old 09-15-2005 | 02:16 PM
waterheater's Avatar
Russ ive been towing the TG for short distances with mine and its been ok. Knock on wood. Take your time and pay attention, uphill it struggles some. I have the 3.92 ratio.
waterheater is offline
Old 09-15-2005 | 03:36 PM
yesrej's Avatar
the tow rating is correct. i would just be very careful and you should be fine.waterheater what is the short distance you tow. towwing the tg seems like alot for the truck but i love it. that makes me feel better about my truck.
yesrej is offline
Old 09-15-2005 | 06:18 PM
I mostly tow about about 500 feet to the ramp. But i have towed a few times to my mechanic, about 15+- miles , on secondary roads, and the interstate, and have been ok. Will change setup in the spring.
Old 09-18-2005 | 01:54 PM
drypipetiger's Avatar
Getting a smaller boat?
drypipetiger is offline
Old 09-18-2005 | 02:24 PM
Only if you do
Old 09-18-2005 | 04:31 PM
t500hps's Avatar
21 and 42 footers
Didn't need the Dodge at all. Ended up with the 2500 back this weekend afterall. Thanks for the help.
t500hps is offline
gotime34
18
10-02-2006 04:13 PM
GregP
12-30-2004 01:59 PM
fountain27ho496
01-22-2003 08:25 PM
Tantrum
10-16-2002 11:23 AM
checkmate zt
05-20-2002 09:47 PM
