Help W/ Alpha one >
Help W/ Alpha one
Help W/ Alpha one
Old 09-26-2005 | 08:24 AM
Default Help W/ Alpha one
Should oil from the upper gear assembly reservoir leak into the u-joint bellows through drive gear assembly. I noticed the oil leaking due to hole in u-joint bellows, which leaked onto lower unit.
grand lake is offline
Old 09-26-2005 | 09:24 AM
Biggus's Avatar
Default Re: Help W/ Alpha one
No, the upper yoke seal has failed and usually there is a deep groove worn into the yoke as well. Replace the yoke and seal.
Biggus is offline
Old 09-26-2005 | 09:27 AM
Outdrive1's Avatar
Masher touches my
After you replace the yoke seal on your drive you'll want to replace that bellows too.
Outdrive1 is offline
Old 09-26-2005 | 11:52 AM
Thanks for the feedback.
littledcsrodshop
Wanted
5
07-24-2008 12:03 PM
srracer
2
04-20-2006 03:49 PM
ch18346
Fountain
1
08-15-2004 08:42 PM
