x factor on 24? >
x factor on 24?
x factor on 24?
Old 10-02-2005 | 07:07 PM
Default x factor on 24?
i am looking to set up an older 24, not sure on hp or x factor?
looking to do mid 80's, can you guys help?
joneill is offline
Old 10-02-2005 | 08:14 PM
Pat McPherson's Avatar
Default Re: x factor on 24?
I have a 1997 24' Superboat straight V, no step, no pad. The prop shaft is about 5" below the bottom of the V.
She has Bravo 1 out-drive, Imco full hydraulic steering, and 280-K planes. Poweris a rebuilt 415HP/502MagMPI that probably makes 15-20HP more than stock.
I run a 28p Bravo 1 prop with the engine topping out at 4800rpm. A three blade prop might make the boat go faster, but it is not as stable...
Top speed recorded this year is 76.4mph GPS one person and low on fuel. With 4 people, gear, and 1/2 tank she tops out at 73-74mph.
The previous owner of my boat had a 502 that was estimated at 550HP. I am not sure how fast the boat really went; the owner said he saw 89-90 on the speedo. My guess is low 80s.
If you are re-rigging an older 24' with a Bravo 1 drive, I would start with the same X dim as mine, approx 17-1/2". Pantera also sets the X at 17-1/2" on their 24'.
If you go higher, you will have to run one of the high $$ 5 or 6 blade props to carry the bow.
500HP will push the boat low 80s, 600HP might have a 24'
knocking on 90.
Full Hydraulic steering and K-280 size trim tabs are a must.
I would also check the hull for any hook that may have developed over the years.
If She is not straight, running above 70mph will be a chore...
Good Luck and Please keep us posted.
Patrick
Pat McPherson is offline
Old 10-03-2005 | 09:46 AM
thayes11's Avatar
IUOE L94
I have a 1980 24' Superboat, basicly stock 454, with bolt on mods. TRS 23" 5 blade Ron Hill propeller, I go 71+ on GPS with 5 people and 1/2 tank gas. . No K-planes.
thayes11 is offline
Old 10-03-2005 | 09:56 AM
Thayes11 give me a buz and let me know how the prop was and any interest in doing the ct river run ? 321-6767 Mike
z.zuperboat is offline
Old 10-03-2005 | 05:19 PM
thayes11's Avatar
IUOE L94
Mike, the best prop I tryed before this one was a 4 Blade Hydromotive, I have used Mirage plus, Bravo 1, The Ron Hill 5 blade has been the best to date, I gained few MPH top end, and 2-3 mph mid range... I will let you try it out and see how it works for your application - if your thinking about buying one. I will give you a call tomorrow. Tom
thayes11 is offline
Old 10-05-2005 | 04:35 PM
thanks for the info Pat, it will be a big help to me.
joneill is offline
5
01-26-2005 12:40 AM
SLINGSHOT
12-30-2003 12:16 PM
OBNOXUS21
06-16-2003 10:22 PM
Dredgeking
03-17-2003 02:10 PM
Dredgeking
General Racing Discussion
3
03-15-2003 09:27 PM
