540ci Innovation 600????'s >
Old 10-04-2005 | 06:15 PM
Default 540ci Innovation 600????'s
I am currently looking at a boat with a set of carbed innovation 540ci 600's w/closed cooling. I am curious as to what it would take to do some modest power upgrades on these to get to the 650-675 range. They have about 150hrs on them.
Corey
lonestar382 is offline
Old 10-05-2005 | 06:24 AM
Whiteknuckle's Avatar
Wink Re: 540ci Innovation 600????'s
Communicate with Innovation Marine and see exactly what you have. Let them tell you what to do.
Whiteknuckle is offline
Old 10-05-2005 | 06:55 AM
velocitypwrbtr's Avatar
Default Re: 540ci Innovation 600????'s
You might be able to put in a bigger cam & port & polish the heads.
velocitypwrbtr is offline
Old 07-05-2009 | 06:05 PM
Can someone explain "closed cooling"?
This same engine setup is in a 1999 Fountain 51' (X 3) and it needs some engine help. Specifically cooling.
damon is offline
Old 07-05-2009 | 08:32 PM
It is going to depend on what cylinder heads you have. You may be able to cam it up, but it is probably gonna take dry exhaust and some decent headwork to pick up 75hp naturally aspirated. You may even have to change intakes and carbs as well. You can also talk to Bob Madara and see what he can do for you.585-654-8583
Damon, closed cooling means no sea water enters the motors. It uses a heat exchanger and fresh water is circulated through the engine (on the more expensive kits the exhaust too) and it is cooled in the exchanger by the sea water, then dumped overboard.
niceguy is offline
Firewalker
17
05-12-2021 12:10 AM
tony manzella
Prop Talk
2
05-26-2008 12:54 PM
Buddy OO
09-04-2007 09:30 PM
merkruzer
4
08-06-2004 02:04 PM
baja272
6
08-29-2002 09:30 PM
