cost to freshen >
cost to freshen
cost to freshen
Old 10-17-2005 | 11:30 PM
Default cost to freshen
How much should one expect to pay to freshen a pair of 420HP mercs? They have good compression, and run good, but Id still like to go thru them and get new rings, bearings, timing chains, valve jobs, gaskets, and then have the carbs dialed in. The only reason i would like to do this is because I dont really know the history of these motors.
MILD THUNDER is offline
Old 10-18-2005 | 08:41 AM
JCPERF's Avatar
Default Re: cost to freshen
JCPERF is offline
Old 10-18-2005 | 08:52 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Then dont touch them
If you take to a motor guy with a dyno by the time you are done you would be very lucky to be at 5k a motor but prob more
klaw is offline
Old 10-18-2005 | 09:21 AM
10k to freshen a pair of stock mercs? I can see if I needed cranks, pistons, rods, etc. I'd be better off buyin some crate 502's for 10g.
Old 10-18-2005 | 10:03 AM
PatriYacht's Avatar
Are they high hours?
PatriYacht is offline
Old 10-18-2005 | 12:05 PM
I had my 502 done over here in South Bend by a reliable race shop for 3600.00. I had him do it for the same reason that you want it done. He found all kinds of problems. Glad I did it. He did everything you posted and put it on his dyno.
REBEL4845 is offline
Old 10-18-2005 | 01:09 PM
Stormrider's Avatar
JC Performance Engines
2500/pc
Stormrider is offline
Old 10-18-2005 | 01:46 PM
baja36ft's Avatar
I Would Say 2200 To 2500 A Motor.
baja36ft is offline
Old 10-18-2005 | 06:58 PM
One motor is a crate merc 454/425, and the other is a 400 cylone that someone supposedly rebuilt to 425 specs. The hours are unknown. The crate merc motor runs real strong, it will pull to 5200. The rebuilt cylcone runs good, but only pulls to 4500, which makes me think valve springs are weak. Either way, Id like to have them gone thru, and set up on a dyno.
Old 10-18-2005 | 07:52 PM
drypipetiger's Avatar
These babies are out right now and the bill is currently up to $6000.00 each. That doesn't include taking them out of the boat and installing back in.....
And to give you an idea of estimates, I was originially quoted $2900. per motor to rebuild. Now $6000. All unforseen extras.....
Any questions??
Attached Thumbnails cost to freshen-glen-lake-mem%5B1%5D.-day-037-large-.jpg
drypipetiger is offline
