oil pickup epoxy >
oil pickup epoxy
oil pickup epoxy
Old 10-19-2005 | 05:19 PM
Default oil pickup epoxy
What kind of epoxy do I use to install a new pick up in my oil pan .I just bought some new Hardin Pans and the cut out in the windage tray is on the right side .Any suggestion ?
boatman747 is offline
Old 10-20-2005 | 07:52 AM
PatriYacht's Avatar
Default Re: oil pickup epoxy
Braze it.
PatriYacht is offline
Old 10-20-2005 | 10:01 AM
GOODT's Avatar
braze or mig it or press in using locktite sleeve retainer
GOODT is offline
Old 10-20-2005 | 10:05 AM
VinMan's Avatar
I wouldnt epoxy it, wont hold for long. small tack weld is the best
VinMan is offline
Old 10-20-2005 | 07:01 PM
can you tack weld while installed on the block
Old 10-20-2005 | 07:04 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Yep.
Just hit it at a spot. not all the way around
US1 Fountain is offline
Old 10-21-2005 | 08:13 PM
Boatman,
The correct way to do it is to remove the pump from the engine, take the cover off the pump, remove the gears, install the screen and check it to see if it is the proper distance from the bottom of the pan ( about 1/2" ) ....... then have it TIG welded or brazed. Then clean it and put it all back together. Then reinstall it on the engine.
BillK is offline
TAZMAN
10
06-28-2007 03:22 PM
ssilverado60
5
03-18-2007 09:54 AM
1BIGJIM
2
04-11-2005 03:04 PM
KNOT-RIGHT
23
12-11-2003 11:58 PM
kaama82
9
03-04-2002 09:17 PM
