Winterizing Question >
Old 11-12-2005 | 03:20 PM
DORaymond's Avatar
Default Winterizing Question
I don't usually take my drives (BravoI's) off the boat for winter storage unless I know I want to work on them through the winter. Is there a good reason to store them inside for the winter? I have never had trouble when I left them on in the past.
DORaymond is offline
Old 11-12-2005 | 03:54 PM
Default Re: Winterizing Question
No reason to take them off. They will be fine. Just dont leave your boat in a lift over salt water for the winter because it will corrode everything.
tj309 is offline
Old 11-12-2005 | 05:39 PM
I would suggest pulling outdrives at least every 2-3 years depending on the hours run in order to visually inspect the universals and gimble brg. And DO trim down for long term storage so as not to stress the bellows. --- Jer
jpclear is offline
Old 11-13-2005 | 05:45 AM
cig1988's Avatar
I'd pull 'em every start of the season to grease the u-joints.
cig1988 is offline
Old 11-13-2005 | 07:10 AM
GOODT's Avatar
should pull once a year to check bellow, gimbel brg, and grease shaft and u joints and to check engine aliginement small price to pay if something goes wrong
GOODT is offline
Old 11-13-2005 | 08:54 AM
DORaymond's Avatar
Thanks for the reply's. I will pull them in the Spring for inspection and lubrication - but they are staying on the boat through the winter.
Old 11-13-2005 | 09:09 AM
GOODT's Avatar
a) if bellows is leaking do you want water sitting in there though the winter to damge u joints seals and eat away at the housing???
b) did you at least change you drive oil ????
GOODT is offline
Old 11-13-2005 | 05:35 PM
Goodt is right. If you are going to bother to pull them at all; Now is the time to do it! --- Jer
jpclear is offline
Chart
3
11-01-2006 04:09 PM
BajaRunner
6
10-17-2006 01:24 PM
G Man
4
10-22-2005 09:54 AM
OG Outlaw 24
10-08-2003 12:04 PM
283CHECK
4
11-05-2002 09:38 PM
