Thermostat housing >
Thermostat housing
Thermostat housing
Old 12-20-2005 | 06:24 PM
nordic95's Avatar
Default Thermostat housing
I just received my new stainless thermostat housings today and I see there are no provisions for the water temp sending unit and the over heat sending unit like on the orignal housing.
Where is the best location on the motor to relocate these units now?
Thanks Nordic95
nordic95 is offline
Old 12-20-2005 | 06:44 PM
GOODT's Avatar
Default Re: Thermostat housing
depends on what motors you have but on most there are provisions in the water jacket cross over in the in take manifold where the therm housing bolts on to the left and or right
GOODT is offline
Old 12-20-2005 | 06:57 PM
nordic95's Avatar
I have not ordered my intakes yet.I am having the motors built as we speak(type).Is it o.k. to mount these in the aluminum intake?Are there any other locations on the motor?I would like to clean up the look around the thermostat.
nordic95 is offline
Old 12-20-2005 | 07:05 PM
marinetrans's Avatar
You can put the alarm in the side of the circ. pump.Should be a 1/2 pipe fitting just above Circ. pump large hose nipple.You'll have to use 1/2 x3/8 reduser and lenghten wire.Merc used to do that years ago.
marinetrans is offline
Old 12-20-2005 | 09:25 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
SS t-stat housing and crossovers?
US1 Fountain is offline
Old 12-20-2005 | 10:21 PM
cuda's Avatar
I have them in my aluminum Merlin intakes.
cuda is offline
Old 12-21-2005 | 06:28 AM
nordic95's Avatar
No,everyone is telling me to stay away from cross overs.
nordic95 is offline
Old 12-21-2005 | 06:29 AM
nordic95's Avatar
And they work and look o.k.
nordic95 is offline
Old 12-21-2005 | 03:41 PM
Ginger or Mary Ann?
Your a wise man.
Old 12-21-2005 | 03:50 PM
Wobble's Avatar
SORE MEMBER
I think that they work well as long as you use the bypass type and use the Mercruiser pressure releif valve. I like the looks and the improved access to the front of the motor.
Bypass wasn't installed in this picture
Wobble is offline
bcarpman
12
05-07-2013 09:00 PM
ak
6
09-29-2008 06:32 AM
ak
4
02-26-2008 05:38 PM
DKerns
12
02-15-2007 01:05 PM
sgr
4
08-22-2004 09:46 PM
