Anchor locker question >
Old 12-22-2005 | 04:45 PM
JasonSmith's Avatar
Default Anchor locker question
Took out the drain to the anchor locker out today on my 29 Outlaw and noticed some moisture in the cavity between the interior of the hull and the anchor locker. I stuck my finger in there and some stuff that did not resemble rotton wood came out. What could it be? If it is foam or backing material, what would be the correct repair?
JasonSmith is offline
Old 12-28-2005 | 09:29 PM
JasonSmith's Avatar
Default Re: Anchor locker question
eh? Nobody?
Old 12-29-2005 | 02:38 PM
Did you make sure that the anchor locker drain tube is attached??
pwam1 is offline
Old 12-30-2005 | 08:41 AM
JasonSmith's Avatar
it was attached, just looks like the sealant failed.
Old 12-31-2005 | 10:13 PM
Don't know if it could happen on a 29, but I once owned an H2X that had a water leak around the bow light and cleat. I gobbed up the backside with sealer, and the problem went away.
pwam1 is offline
pwrbotr
03-02-2021 04:16 PM
Stalkin
Cigarette
6
04-02-2007 09:07 PM
BajaFresh
02-27-2007 10:36 PM
merkruzer1
Detailing, Painting, & Fiberglass
13
07-04-2005 11:43 PM
Advantage
Baja
7
04-26-2002 07:37 PM
