Shorter drives and Water pressure >
Old 02-02-2006 | 06:35 PM
Default Shorter drives and Water pressure
At what point when installing IMCO -2 shorty would one start to worry about the H2o pressure ? Is it a speed thing or what? I currently have a low water pick up Bravo I and have no problems with this as of yet but if I install a shorty am I asking for water pressure problems and if so what is the cleanest simplest way to deal with it? Regulate it or dump it over .....need some help.
please advise.
Bryan
Bryan Rose is offline
Old 02-02-2006 | 07:03 PM
racinfever's Avatar
Default Re: Shorter drives and Water pressure
leave the plug out of the speedo port , top of lower gear case!
racinfever is offline
Old 02-02-2006 | 07:45 PM
Huh................................?
Old 02-06-2006 | 05:41 AM
Strip Poker 388's Avatar
Rob
I hear that the Imco will raise water pressure
Strip Poker 388 is offline
Old 02-06-2006 | 06:22 AM
Payton's Avatar
Charter Member #927
and the Bmax crescent shortie doesn't. or so I've been told.
Payton is offline
Old 02-06-2006 | 09:42 AM
zt260's Avatar
Use a pressure relief valve and dump the excess.
zt260 is offline
Old 02-06-2006 | 07:15 PM
Hot Boat's Avatar
Team Dysfunctional
My presure went up 10 psi with a imco 2" shorty. My stock drive was also a low water pickup
If it aint broke .... I can break it....
Hot Boat is offline
Old 02-06-2006 | 07:32 PM
where to get and what kind?
Old 02-06-2006 | 07:39 PM
zt260's Avatar
Mine is from Teague, and feeds off the sea strainer. It's also adjustable from 15-30psi. You could just T it in line if you’re not straining. KPM racing also has some slick ones. Trick Marine can help with those.
zt260 is offline
AAM
Sonic
3
08-09-2007 08:25 AM
Rebel_Heart
Prop Talk
3
05-14-2006 08:21 AM
Payton
35
01-29-2006 03:54 PM
Smitty
Baja
23
10-10-2005 08:17 AM
WildWarrior
Cigarette
13
07-13-2005 09:50 AM
