Gauge Question >
Gauge Question
Gauge Question
Old 02-05-2006 | 02:05 PM
88formula223's Avatar
NO WAKE ENFORCER
Default Gauge Question
What All Is Involved In Chaging The Guages, Do The New Ones Just Hook Up To The Old Wires Or Are Their New Sensors To Be Put In?? I Want A Gps Speedo Probly Livorsi, Where Do I Get The New Dash Panel?
Thanks Pj
88formula223 is offline
Old 02-05-2006 | 10:14 PM
mopower's Avatar
Toxic FORMULA
Default Re: Gauge Question
VDO guages for Formula are European and some of the senders work backward as compared to American guages , fuel sender being one of them. I already did this change. I think the oil pressure was backward too. Here I am the first time out with a full tank. The farther I went the fuller it got .
mopower is offline
Old 02-06-2006 | 01:28 AM
RedDog382's Avatar
Fuel sender needs to be changed. I believe oil and water temp senders are compatible. Check with tech at Livorsi or Fred at Trick Marine, they will both be able to tell you what you need.
RedDog382 is offline
Old 02-06-2006 | 04:41 PM
NO WAKE ENFORCER
thanks
Sick Stinger
Velocity
5
04-19-2008 09:06 AM
88formula223
06-22-2007 11:35 AM
outlawinil
3
01-30-2004 09:38 PM
Shah Mat
10-10-2003 03:13 PM
