Two questions
Old 02-05-2006 | 08:21 PM
dean51267's Avatar
Default Two questions
I have cracks nstress points in the gel coat, like i ncorners of the cock pit and the like. I know they are common, how hard are they to fix?
The interior gel coat of the cock pit is black. Can I paint it white, or is this not even a good idea, it gets extremly hot.
Thanks.
dean51267 is offline
Old 02-06-2006 | 08:18 AM
Default Re: Two questions
Answer to question # 2 - Determine what type of "black paint" is on the surfaces now. Use a rag wetted/ damp with the solvent MEK and wipe the surface in a back and forth motion 50 times. If the paint disposlves easily then you should use a simple paint that does not have strong solvents such as latex or alkyd. If the paint does not disolve, it is important that the surface be sanded first then apply ANY type of paint over top.
James is offline
stevesxm
1
06-28-2007 10:03 AM
OkieTunnel
7
03-08-2006 03:21 PM
buck183
Active Thunder
3
05-16-2004 05:48 PM
Red Stripe
7
05-28-2002 06:48 AM
mama tryed
02-12-2002 06:21 PM
