juice ssos25
I'm a new ower of a 99' 25'0e ssos w/twin merc 250 EFI'S XL on 5'' jack-plates so the moter's sit higher, the prop shaft's r app.1'' above the bottom, she run's 85 - 90 @ 5800-6k with 3/4 throttle, i'm running 14-1/2 x 30's clever's w/small shaft's, my ? is, do i go with 15-1/2 x 30's or 32's i'm looking mid-90's+ who know's anything about a 25' OE SSOS I need input
& a set of prop's, any buddy have sometthing that may work, I've all so have a bad bunny hop @45-50 to 65-70 i'm thing a tunnel tab & i'm in central FL. Thank's juice
I am assuming that you have no control of trim. I would forget about the "bunny hop" for now and try different props first. Contact a outboard prop distributor that inventories different pitch props. Go to the prop section of the board and E-mail them to find out if they carry and will let you try one of their props.
http://www.offshoreonly.com/forums/f...play.php?f=165
Mark
Mark
congrats on your oe,
post some pics of it
what does your boat weigh,im thinking with your motor your not to bad in the high end of it[you maybe out of motor]
go to screamandfly.com,there is the gurus for outboards, props,jack heights, there
scott
scott
I will post pics when i get them in my PC, i hope soon, i'm getting a pair of 4 b 30's bravo's, now waiting for the weather to test, these will kill my bottom end but hope to see 90+, i've turn'ed my drive's in to see if that help's
Fast Priorty II Nor-Tech
juice, I had a 1990 25 ft oe with 2.4s, never was able to get over 92-93 with it. tried all kinds of props with it, 14 1/2 x 30 were the all around best props for the boat. witlh larger props it really liked to hop. I always thought the tunel on that boat was took big thus not giving it enough lift. good luck
Bill, what kind of rpms @ 92 w/2.4's, i'm running 85+ @5800-6k & hitting rev-limiter's @ 3/4 throttles, i think w/32" props i would be @90+ , My boat is about 3300 LB'S dry , add motors 250s merc EFI , 450LBS X 2=900LBS=4200LBS. + I need more prop. see ya ,
I had aa 25 and raced in in Stock boat - started with 200's then 2.4 then 2.5 this has been years ago but I don't remember ever going over 95 - ran 4 blade for stern lift 28's & 30's - I fool around with gear ratios - I tried a tunnel tab - lots of work and still hopped - smooth water and you have a bunny - a little chop and it was fun - The boat was called "ballistic" worked well fro a couple of years - I still have a set of 3 blade 28's and 30's if you need spare props priced right
juice, it was so long ago i do not remember what rpms i was turning. might call oe direct they might have answers. 4 bladers might be the answer. my boat was named push it and is pictured on oe web site good luck bill
