Trailer hitch setup for 2500HD?
Old 02-20-2006 | 03:14 PM
miamioffshore's Avatar
Default Trailer hitch setup for 2500HD?
I have a 2500hd duramax and I need to setup it up to tow a Cafe Racer/Top Gun. My question is what should I use for trailer hitch (receiver) , I know I need a Class 5 hitch. I also want Weight Distributing hitch with sway control. Need a MINIMUM of 14000lbs weight distributing capacity, but would like more. What system does everyone recommend.
miamioffshore is offline
Old 02-20-2006 | 04:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: Trailer hitch setup for 2500HD?
http://www.offshoreonly.com/forums/s...vy+hitch+balls
Get the Putnam XDR hitch or the Reese Titan-V hitch receiver. Then look into the Equalizer hitch if you are bent on sway control, but I can't see it working for what its worth on a boat.
Sydwayz is offline
Old 02-20-2006 | 04:47 PM
ChrisK's Avatar
Moderator
I put one of the putnam hitches on my old 2500HD, its rated for 15,000lbs weight carrying, something like 16 or 17,000lbs weight distributing. Its a monster and easy to install. I got one for Jason's Dodge dump truck as well, and after installing it they promply bent the frame, hitch, AND reciever with the dump body... but it survived! it didnt break or crack a weld on it. just unusable due to the damages.
ChrisK is offline
BillR
2
10-24-2007 08:36 AM
Sydwayz
2
05-15-2007 10:35 AM
Son of a Gun
2
01-03-2007 09:17 PM
sakoutis3
12
04-04-2006 10:05 AM
miamioffshore
27
03-22-2006 01:50 PM
