330/454 Bravo 1 >
330/454 Bravo 1
330/454 Bravo 1
Old 02-26-2006 | 01:00 PM
Default 330/454 Bravo 1
I have a 1990 Bravo 1, 330/454. When I start it up, it will run for around 10 to 15 seconds and shut off, just like if I were to turn the key off. All the gauges go dead. Is there an engine shutdown integrated with the audio alarm system? I know the oil pressure switch needs replacing. I tested it. Would this shut the motor off or just sound the audio alarm?
waterfun is offline
Old 02-26-2006 | 01:08 PM
GOODT's Avatar
Default Re: 330/454 Bravo 1
If efi or mpi mtr there is a shut off that works off of oil press that works off of its own sender and is either over the oil filter ( if block mounted ) or teed off where the regular sender is
GOODT is offline
Old 02-26-2006 | 01:13 PM
This motor has a Quadrajet carb on it.
waterfun is offline
Old 02-26-2006 | 01:27 PM
GOODT's Avatar
does it have elet fuel pump????
GOODT is offline
Old 02-26-2006 | 01:50 PM
No. It has the old cam driven pump.
waterfun is offline
Old 02-26-2006 | 01:56 PM
GOODT's Avatar
ok lets start at square 1
how long before it will start back up????
does ing switch have a fuse or circut breaker?
GOODT is offline
Old 02-26-2006 | 02:03 PM
It will probably start up in less than two minutes. I do not see a fuse or circuit breaker in the ignition switch system other than the main 50-Amp breaker.
waterfun is offline
Old 02-26-2006 | 02:07 PM
have had a lot of older boats with ingition swith problems do the same thing jump the back side of switch to check or use a amp tester to check.
brian41 is offline
GOODT's Avatar
with out going through 50 questions.. id first look at the coil after the mtr stalls feel coil check if hot a quick guess would be a shorting coil... would cause mtr to die and could short dash
what happens is it gets hot, windings expand and short
cools down and windings separate
have seen it many times never saw dash short but it could since the purple wire to to coil also powers your gauges
GOODT is offline
Old 02-26-2006 | 02:30 PM
I hot wired this thing last fall to winterize it. Ran like it always did. Thats why I'm leaning toward the o/pressure switch.
waterfun is offline
