The New And Improved Avanti Motor!!!!! >
Old 03-02-2006 | 04:19 PM
TeamSaris's Avatar
Driver-441
Racer
Thumbs up The New And Improved Avanti Motor!!!!!
Tis will be one sick Avanti!!!!!
TeamSaris is offline
Old 03-02-2006 | 04:30 PM
TeamSaris's Avatar
Driver-441
Racer
Re: The New And Improved Avanti Motor!!!!!
Yeeeeehawwww!!!!!!
Attached Thumbnails The New And Improved Avanti Motor!!!!!-avantimotorsracks3-small-.jpg   The New And Improved Avanti Motor!!!!!-avantipulleys1-small-.jpg   The New And Improved Avanti Motor!!!!!-avantistack1-small-.jpg
Old 03-02-2006 | 04:35 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: The New And Improved Avanti Motor!!!!!
1 more.
Attached Thumbnails The New And Improved Avanti Motor!!!!!-avantistacks5-small-.jpg
Old 03-02-2006 | 06:55 PM
Pat McPherson's Avatar
OK give us the poop.
Cubes? Horsepower? Fuel Injection?
Patrick
Pat McPherson is offline
Old 03-02-2006 | 07:26 PM
TeamSaris's Avatar
Driver-441
Racer
HP- expected at least 600
CID- 496
Computer- accel so yes it is injection with enderle stacks.
Old 03-02-2006 | 08:05 PM
SUPERSTITIOUS's Avatar
Nice!
SUPERSTITIOUS is offline
Old 03-02-2006 | 08:08 PM
fastedy's Avatar
What did it start out as, a Merc496? I have a HP3 496 and was wondering what I could do with it, will a carb and intake fit on it and are the headers the same bolt pattern as a Gen 5 block. I havnt been able to find any parts for it if I wanted to remove the fuelinjection.
Eddie
fastedy is offline
Old 03-02-2006 | 09:02 PM
FASTERDAMITT's Avatar
That's pretty!
FASTERDAMITT is offline
Old 03-03-2006 | 06:22 AM
Eddie
Eddie the the new GM 496 engines including the HP3 are not good candidates for more than 600HP without new internals. And I don't believe you can convert to a carb either; remember distributer-less ignition, coil packs for each cylinder, you need the computer controls.
If you still have your HP500EFI, that is the engine to boost; and I do mean that literally. Lots of supercharger packages to bolt on that baby to make 750+HP...
Patrick
Old 03-03-2006 | 06:25 AM
CID- 496
I guess when you get that baby dialed in she'll run mid to high 80s...
Patrick
