easy way to remove 3m 5200 ? >
Old 03-04-2006 | 12:18 AM
Question easy way to remove 3m 5200 ?
any one out there use 5200 to mount trim tabs. is there any easy way to remove it? besides the razer baldes?
thanks sk
soinc is offline
Old 03-04-2006 | 12:21 AM
racesdad's Avatar
Default Re: easy way to remove 3m 5200 ?
with a frickin chisel,
no easy way
maybe try MEK
racesdad is offline
Old 03-04-2006 | 12:43 AM
Catagory5's Avatar
3m adhesive remover and elbow greese. Use the razor blade first to remove the bulk
Catagory5 is offline
Old 03-04-2006 | 07:24 AM
Ditto on the remover made for removing the stuff. 5200 is tough.
happy hours is offline
Old 03-04-2006 | 08:53 AM
Thanks guys off to the marine store I go.... wish i thought about using this stuff before I used it...oh well.
Shawn
soinc is offline
Old 03-04-2006 | 09:54 AM
SKRAMER's Avatar
Good luck hope you can fix gelcoat. I can't ever get that stuff off without messing something up. Use the 4200 if you think your going to take it apart again.
SKRAMER is offline
Old 03-04-2006 | 10:11 AM
Primal Instinct's Avatar
West Marine has a small spray bottle of adhesive remover...can't remember the name but it's a white bottle with red top, about $10 bucks...let it soak a bit...
Primal Instinct is offline
David Stotz
Do It Yourself, Boating on a Budget
13
03-19-2008 07:17 PM
customryder
05-15-2006 09:22 PM
chattviper
03-03-2006 04:20 PM
rv
11-17-2005 06:29 PM
Harper220
07-21-2005 05:37 AM
