#6 questions >
#6 questions
#6 questions
Old 03-07-2006 | 10:46 PM
OkieTunnel's Avatar
Default #6 questions
What is the difference between dry sump and wet sump #6's? What is the difference between the old style #6 and the new swept skeg? I am considering a boat with wet sump #6's and would like to know the differences.
OkieTunnel is offline
Old 03-07-2006 | 11:11 PM
HotPursuit's Avatar
Default Re: #6 questions
Dry sumps run little or no oil .Wet sumps are filled lower and upper.Dry sumps depending on HP and hull design will increase speed 3-6 mph.Less gear drag with no oil.
New swept back skeg design should give better high speed handling.Different shape and style.
HotPursuit is offline
Old 03-08-2006 | 07:09 AM
OkieTunnel's Avatar
Thanks for the info.
Old 03-08-2006 | 07:47 AM
Nykamp's Avatar
The real early K drives had the tie bar mounted on the back of the drives and the newer ones have the tie bar mount on the top of the case. If it is the real early #6 K drives make sure it has had the work done to handle the updated gear sets.
Nykamp is offline
Old 03-08-2006 | 08:22 AM
Spine Tingler's Avatar
You can't afford a new boat
Spine Tingler is offline
Old 03-08-2006 | 02:26 PM
Damn Scott, OUCH!!
shark42 is offline
Old 03-08-2006 | 02:49 PM
OkieTunnel's Avatar
Shart 42??? Oh, shark 42
I can't afford well adjusted's new boat thats for sure.
Old 03-08-2006 | 03:21 PM
44MTI's Avatar
He only thinks he's getting a new boat.
44MTI is offline
stevesxm
1
06-28-2007 10:03 AM
dean51267
Detailing, Painting, & Fiberglass
1
02-06-2006 08:18 AM
buck183
Active Thunder
3
05-16-2004 05:48 PM
Red Stripe
7
05-28-2002 06:48 AM
mama tryed
02-12-2002 06:21 PM
