prop venting >
prop venting
prop venting
Old 03-09-2006 | 07:15 AM
Default prop venting
i have twin 200 promax on a 27 activator i run with 26 hydromovtives and was wondering any benifit to venting props . by cutting holes thanks
JERSEY DEVIL is offline
Old 03-09-2006 | 07:59 AM
throttleup's Avatar
Default Re: prop venting
Are you experiencing any difficulties getting on plane, now? If so they may improve your planning capabilities.
Julie
throttleup is offline
Old 03-09-2006 | 08:37 AM
have to feather it getting on plane , it is ok when i use bravos but not so good with hydros but top end is 3mph better with hydros
Old 03-09-2006 | 09:42 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: prop venting
If you are feathering them, you don't want to vent them. They are already venting themselves.
This is one of the issues with the blade design on the Hydros. This is also one of the benifits the blade design of the Bravo 1 offers. You may get the best of both worlds if you Lab Finish the Bravo 1's. I'm only assuming the Bravo's aren't Labbed.
[email protected]
bbladesprops is offline
Old 03-09-2006 | 09:50 AM
throttleup's Avatar
Do you have flare rings on the Hydro's? On the aft end of the prop the tube should increase in diameter. If you don't have the flare ring installing one may eliminate the prop ventilation while getting on plane. You would have the best of both worlds without the cost of a lab finish.
Matt
Old 03-09-2006 | 09:57 AM
The diffuser may or may not help your planing.
The diffuser may or may not affect your speed negatively.
[email protected]
Old 03-09-2006 | 10:23 AM
i have no rings on hydros the bravos were nice all threw the powerband but the hydros were real nice at top end in nasty water.the bravos were slower a wot and a bit flighty. did a say the activator is a step bottom.the hydros dont seem to be wider at the aft end.
Old 03-09-2006 | 11:45 AM
throttleup's Avatar
The flare rind may reduce the ventilating while getting on plane. Yes, the Bravos are a better all-around prop than the Hydros are on your boat. ]
Flare rings can be installed on your props easily, installed they are $40 each.
Matt
Old 03-09-2006 | 12:24 PM
have to put it back in the water and mess with it a bit , thank you for all your help. be in touch
Old 03-09-2006 | 06:06 PM
Throttle up vented my Hydro's, made a huge difference. It allowed my 250 Efi's get to get that "jump" they needed. Had similar experience with the Bravo's.
Johno is offline
