Center of Gravity on boats?? Question >
Old 03-14-2006 | 09:36 AM
BAJA WILL's Avatar
Registered User
Default Center of Gravity on boats?? Question
OK so their are many Mfg's staggering their motors in the engine compartment to better the CG like Fountain, Cig, OL, I am sue their are others ( and getting great results)>>> OK so my question is if you replace a current set up with the new Ilmors they save you about 600lbs, wouldn't that better the CG on a regular side by side set up?? Achieve the same results if not better?? Just looking for insight and opinions
WILL
BAJA WILL is offline
Old 03-14-2006 | 10:07 AM
Stormrider's Avatar
JC Performance Engines
Default Re: Center of Gravity on boats?? Question
You will be reducing the weight in the rear, but staggering sets your COG forward and lower in the boat.
It also gets your dives lower and closer together.
Regardless, it would be a MAJOR job to change a standard config to staggard, so I'd take the weight reduction anyday!!!
Stormrider is offline
Old 03-14-2006 | 11:00 AM
BAJA WILL's Avatar
Registered User
Stormrider,
Great point, I forgot about staggering being able to put the drives closer. However my point is by making the rear lighter that will move COG farther forward? Thus improving performance?? Just things to ponder.
WILL
Old 03-14-2006 | 11:08 AM
Stormrider's Avatar
yea, i'd agree w/ you on that.
You could always add some lead forward if the boat needed it.
I think lighter would be better anyway.
Old 03-14-2006 | 07:56 PM
monstaaa's Avatar
the less wetted surface the better. every boat is different. tough to make that call. one thing for sure a good c,g will run the boat pretty darn straight without x-cess trim,,,, like this, therefore ending up with very efficient speed.
monstaaa is offline
Old 03-14-2006 | 09:11 PM
Strip Poker 388's Avatar
Rob
What is considered a good CG and where should it be ?
Strip Poker 388 is offline
Old 03-15-2006 | 07:10 AM
monstaaa's Avatar
low, inside, and pending step locations and bottom configuration avg. 70/30 split
monstaaa is offline
Old 03-15-2006 | 07:44 AM
CigDaze's Avatar
WILL
Quick answer, yes the CG will move forward. How this effects the performance, it's impossible to say.
CigDaze is offline
Old 03-15-2006 | 08:47 AM
Rob
Bo on my 388 ..Hustler said it was at the back of the front seat.When I tested it It is about the sterring wheel.Good or bad??
Rob
TSUNAMIRACING
09-12-2007 12:49 AM
1bagger
Cigarette
0
05-13-2007 08:50 PM
Enforcer2
2
12-27-2005 08:42 AM
offthefront
15
03-20-2005 10:57 AM
vtec
03-06-2003 08:34 AM
