crazy wiring probloms, oh no!!!! >
Old 03-23-2006 | 09:58 AM
98itrwhite's Avatar
Default crazy wiring probloms, oh no!!!!
i replaced my gauges this winter with new gaffrig ones and disassembled the dash with all the switches so i could paint the dash. there are so many wires under there, and its a mess. i have all of these rocker switches on the dash and i am getting 8 volts from my ground wire on my meter. i think i have an + on the wrong lug on one of my switches and since the grounds are all linked togather its back feeding 8 volts. my question is does any one have a diagram for the rocker switches? showing what wire clips to what lug on the back of the switch. they are very popular swichtes and they came factory on older boats. the only other thing i could think of is that i had the engine out over the winter and mybe a ground is not connected and making things go nuts.
here is a pic of the switches, sorry i know its hard to see them
98itrwhite is offline
Old 03-23-2006 | 06:41 PM
monstaaa's Avatar
Default Re: crazy wiring probloms, oh no!!!!
check for good grounds. then voltage. as to see if you replaced a wire on the wrong terminal. for the most part center pole is hot and the outer is power to accesorie.
then if that doesnt work,,,, take out your cutting pliers.
just kidding take your time look at it for a while and youll figure it out.
good luck.
monstaaa is offline
Old 03-24-2006 | 07:20 AM
98itrwhite's Avatar
last night i ran a ground from the battery and hooked it to my ''daisy chain grounds and i got everything working nice. but i still some where have power going through a ground. i keep testing and i can find it.
Old 03-24-2006 | 09:25 AM
Wally's Avatar
Were doomed!
if you dont have it grounded power will show up on the ground side....if when you ran that ground to the daisy chain straight from ground and nothing acted funny then most likely everything is ok...you just need to find where you dont have the ground hooked up. If you did have power hooked up to the ground side then when you hooked up that ground straight form the battery it would have blown a fuse or made something act goofy/overheat/short etc....
-Wally
Wally is offline
Old 03-24-2006 | 02:08 PM
98itrwhite's Avatar
very true, i think i just have to find the missing ground wire. i am going back at tonight. thanks for the help
Old 03-24-2006 | 09:12 PM
monstaaa's Avatar
find the main ground from the engine harness, and see if thats missing.
monstaaa is offline
Old 03-25-2006 | 07:33 AM
98itrwhite's Avatar
thanks everyone, i found the problom. found all the grounds and everything work great.
nocigarette
29
06-30-2008 06:59 PM
BY U BOY
04-01-2008 03:55 PM
GCAT911
Fountain
35
08-30-2007 03:49 PM
hp500efi
6
04-30-2007 10:47 PM
fountain525sc
11-30-2002 01:55 PM
