GM Cam specs???  1.8 Rockers???? >
Old 03-29-2006 | 07:34 PM
wtpowered's Avatar
Default GM Cam specs??? 1.8 Rockers????
Anyone know cam specs for GM cam # 4364???
I can't find the info anywhere.
ALSO Why use the 1.8 Roller Rockers ?????
What are the advantages and disadvantages?
I have a set on my stock heads.
Can they be used on a set of Edelbrock alum heads?
wtpowered is offline
Old 03-29-2006 | 07:36 PM
Elite Marine's Avatar
Default Re: GM Cam specs??? 1.8 Rockers????
More lift than 1.7 ratio rockers.
Elite Marine is offline
Old 03-30-2006 | 09:11 PM
ratman's Avatar
some engine builders run 1.7 on int and 1.8 on exhaust on stk bbc heads to help the exhaust flow better. or viec versa to help the intake
ratman is offline
Old 03-30-2006 | 11:28 PM
3904362 Mechanical Flat Tappet
This mechanical flat tappet is an LS-6 street mechanical lifter cam. (Use spring P/N 3970627.) The duration at lash point in degrees (intake/exhaust) is 307/298; duration at .050" tappet lift (intake/exhaust) is 242/242; and maximum lift with 1.7:1 rocker ratio (intake/exhaust) is 496/492. Valve lash is .024/.028 and lobe centerline is 114 degrees.
Back4More is offline
Old 03-31-2006 | 09:48 PM
wtpowered's Avatar
Thanks for the specs.....
How much more lift do I get from the 1.8 roller rockers?
Old 03-31-2006 | 09:52 PM
wtpowered's Avatar
Will I have any problems using the 1.8 rollers on the Edelbrock heads?
Old 04-01-2006 | 06:39 AM
MOP
When you change rocker arm ratio you change more then the lift, on a marine engine with wet exhaust you can induce reversion. You can get some excellent info by Googling "Cam shaft theory" and "Rocker arm theory" It is a good idea to take the time to get the right technical info to get the power you want and most of all to protect you engine.
Also you may want to consider getting the lift from the cam, though slight high lift rockers take more power to actuate the lower the rocker arm ratio the less valve train stress and wear.
Phil
MOP is offline
Fenderjack
1
04-26-2007 05:28 PM
WETTE VETTE
1
12-17-2002 05:43 PM
traviss
4
01-31-2002 06:19 PM
US1 Fountain
0
01-27-2002 11:26 PM
