33 Fountain Prop Question
1990 33 Fountain, 454 Mags. Currently running 25P 3 blades. Anyone have experience with this set up? Boat will run in the upper 60's WFO at 4900 rpm with a light fuel load, trimmed out level tabs. Would like to try 4-blade. Thoughts? Suggestions? Anyone?
Non-Steps have a hard time getting enough bow lifty with a 4 blade. Those motors should be turning 5300 at WOT but your speed sounds about right for your set up. 4 Blades will look good on the trailer but in the long run your probably better off with what you've got.
