tabs
Old 04-13-2006 | 06:57 PM
camptappakeg69's Avatar
Default tabs
Hi everyone been lurking around this site for a few months,lots of great stuff
Can't afford to upgrade my ride this year like I wanted...I have a 22 stingray w/350 mag/ bravo 1/runs in mid 60s...sluggish getting on plane when have more than 2 people in it..but other than that runs great for a small block
Would trim tabs help?? if so hydraulic or electric??
electric look easy to install, would I need heavy duty/racing tabs for this boat or can get away with cheaper ones??
any input would be great, season starting soon
thanks, Mike
camptappakeg69 is offline
Old 04-13-2006 | 07:26 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: tabs
thanks, Mike
hydralic and yes also what prop?? If a aluminium try a 4 blade aluminium also try some ss props.
TeamSaris is offline
Old 04-13-2006 | 07:33 PM
GOODT's Avatar
Default Re: tabs
trim tab my help but before I did that I would play with the prop, sounds like your is set up more for top end rather than"out of the hole"
keep in mind that what you gain in bottom end you basicly loose in top end
GOODT is offline
Old 04-13-2006 | 07:56 PM
Default Re: tabs
Thanks for input, have 21ss laser, can't remember the pitch,
seems fine getting out of the hole unless i have people in the back seat, would the tabs help or should i change props, or maybe just no more than 1 passenger Don't want to lose any topend
Old 04-13-2006 | 11:24 PM
Catagory5's Avatar
Default Re: tabs
If you decide to go with tabs I'd use a set of Lenco's on your boat
Catagory5 is offline
GEORGE YURICK
Superboat
10
04-13-2007 12:23 PM
slobaja
Baja
14
04-11-2005 07:59 PM
ChromeGorilla
11-30-2004 07:03 PM
robert johnson
1
05-16-2003 10:31 PM
