Correct riser/manifold temp?
there really isnt a correct answer there are too many variables because some water bypasses the block and goes directly to the exaust, long and short of it is you should be able to rest your hand on top of the riser with no problems, normally the stb side runs a little hotter then port, 90s to low 100s are common
