Tie Bar Question
Old 04-24-2006 | 11:24 AM
SKRAMER's Avatar
Default Tie Bar Question
I'm looking for a tie bar for a twin alpha one settup. Is there a reason they didn't come with one? The drives are NOT counter rotation. Is it a bad Idea to put one one? Does anyone have one I can buy. Thanks Scott
SKRAMER is offline
Old 04-24-2006 | 12:34 PM
ratman's Avatar
Default Re: Tie Bar Question
how does that thing ride without counter rotating screws?
ratman is offline
Old 04-24-2006 | 01:10 PM
SKRAMER's Avatar
Well the boat I'm tring to finds this for is a wellcraft novaIII. Its not mine and have never been on it.
SKRAMER is offline
Old 04-24-2006 | 01:21 PM
Pantera24's Avatar
I know they do make them. My 28' Pantera had twin Alpha SS drives with it and were not counter rotating. The boat had a great ride and never had any handling problems.
Pantera24 is offline
Old 04-24-2006 | 02:33 PM
Scarab3DMC's Avatar
Ahemmm...call Brian@ XS...???
Scarab3DMC is offline
Old 04-24-2006 | 02:36 PM
BajaRunner's Avatar
yes you can get them. my baja 265 force had twin alphas. rode fine, but when you stopped fast, it pulled to the right hard, torque steer.
BajaRunner is offline
Old 04-24-2006 | 03:42 PM
hunster's Avatar
I put one on my 29 scarab years ago. I had a worn gimble on the counter and wanted to make it through the summer. Got it from eddie marine. You will have to measure the center to center on the drives. Works great! Pic here http://www.offshoreonly.com/forums/s...d.php?t=127600
hunster is offline
Old 04-24-2006 | 03:49 PM
There is one on ebay. Do a search under tie bar.
floatingphil is offline
Old 04-24-2006 | 09:54 PM
SKRAMER's Avatar
Thanks Guys.
SKRAMER is offline
Old 04-24-2006 | 10:32 PM
hunster's Avatar
There is a latham bar I found for bravo's. I researched these probably too much but look at the latham somple heim joint ends, and then look at the eddie marine where it mounts to the saddle. I think eddie marine design allows for more mis alignment of the drives without stress on the end. That was why I opted for that design, just seems to be a beefier bar all in all. Check it out , what do you think?
http://www.eddiemarine.com/cart/deta...&CategoryID=25
hunster is offline
