Triple application?????? >
Old 04-24-2006 | 11:04 PM
tomtbone1993's Avatar
Default Triple application??????
how does your standard center engine setup on your exhaust tailpipes mount to the fiberglass????
tomtbone1993 is offline
Old 04-25-2006 | 10:26 PM
monstaaa's Avatar
Default Re: Triple application??????
a little clearer?
monstaaa is offline
Old 04-25-2006 | 10:42 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My buddies trip 42 is mounted just like the other motors. Just plain ol hard rubber exhaust hose. The long tailpipes with out the support seemed questionable to me, but he never had any problems with the center exhaust. Merc/Gil exhaust.
US1 Fountain is offline
Old 04-26-2006 | 10:50 AM
my old setup was CMI Big tubes, they came out above the swimplate form. I have switched to E-Tops, had to redrill the standard Bravo setup. The center tail pipes go on the outside of the rear engines....my question is how do the tailpipes mount to the fiberglass??? does that make any sense
Old 04-26-2006 | 11:02 AM
pachangalpina's Avatar
Mine were pipes that went thru the transom and had a trim plate with an o-ring that slid over the tail and mounted to the transom. I now have pneumatic mufflers that mount directly to the fiberglass.
pachangalpina is offline
Old 04-26-2006 | 11:04 AM
Cool Trips's Avatar
Does the center engine exhaust through four holes on the curved part of the hull below the platform?
Cool Trips is offline
Old 04-26-2006 | 11:20 AM
yep, it has a flush 4" tube that leads to the other holes
Old 04-26-2006 | 12:04 PM
Cool Trips's Avatar
I had to look There is a flange on the inside of the transom. The pipe stops even with the hull inside the "molded platform" Its called using the boat as a muffler Its not bad when your moving but it does shake the boat when your at the dock.
Attached Thumbnails Triple application??????-dsc00032.jpg   Triple application??????-dsc00033.jpg
Old 04-26-2006 | 12:31 PM
the second picture is perfect!!!! so how does the stainless tube mount to the hull?
Old 04-26-2006 | 01:19 PM
Cool Trips's Avatar
There is a pipe with a flange welded to it. The flange is screwed and sealed to the transom. The long pipe hooks to that with exhaust hose. I know its dirty, I'm still spring cleaning
Attached Thumbnails Triple application??????-dsc00034.jpg   Triple application??????-dsc00035.jpg
