How to disconnect an trim pump from an outdirve under pressure >
Old 05-04-2006 | 02:50 PM
gripit's Avatar
Default How to disconnect an trim pump from an outdirve under pressure
I want to know how to disconnect a trim pump under pressure from an outdrive that is stuck in the half way out position. I imagine it will be under alot of pressure from the drive and as soon as I loosen the line the fluid will squirt all over the place. Please advise.
gripit is offline
Old 05-04-2006 | 03:38 PM
ratman's Avatar
Default Re: How to disconnect an trim pump from an outdirve under pressure
i loosened the line where it comes out of the ram, i unweighted the drive to undo the last few threads and then put the line in a bucket to catch the oil.
ratman is offline
Old 05-04-2006 | 07:50 PM
gripit's Avatar
Is there any pressure releif values on this style pump? Also, I really do not have access to the ram because the boat is on a lift. Any tips to do this by undoing the hydrolic lines from the pump in the engine compartment?
gripit is offline
racer-x6
1
06-18-2008 12:15 PM
mmwalters
3
07-11-2006 10:51 AM
stevesxm
5
05-09-2006 06:45 AM
zt260
17
09-18-2005 02:42 PM
mmwalters
12
08-25-2004 07:31 AM
