Maximus On Formula 382 Fastech >
Old 05-08-2006 | 09:24 PM
sea-crit
Default Maximus On Formula 382 Fastech
This is a copy my post in the Formula section
Well, I got a chance to run the boat today with the new props.
I still have some dialing to do but the preliminary report is:
99 382 with 1.5 Bravo Performance drives on Stelings boxes 500EFI with head work, bumped up cams and ECU mods ? 550ish HP (no dyno). Light load, 1/2 tank fuel
Lake Michigan, Calm
Water Temp 47
Air Temp 71
14 7/8 x 28 pitch labbed Bravo 1s 3500 RPM 45 mph
15 1/4 x 28 pitch labbed Maximus 3500 RPM 54 mph
Top Speed GPS:
Bravos 76 mph @ 5500 rpm
Maximus 76.8 mph @ 5000 rpm
I'm in debate over whether to sell these and drop to 27 pitch, but I really like the cruise speed and in the real world, WOT is a rare occurrence
Old 05-09-2006 | 09:19 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: Maximus On Formula 382 Fastech
Max may be able to be worked even more to pull more rpm.
26 Max is another option.
I prefere the, see what can be done to the 28 Max.
[email protected]
bbladesprops is offline
Old 05-09-2006 | 06:19 PM
throttleup's Avatar
Default Re: Maximus On Formula 382 Fastech
You can probably get a couple hundred RPM out of the Maximus props as Brett has stated but if you can trade them for a smaller pitch you may want to consider it.
Julie
throttleup is offline
Old 05-09-2006 | 09:41 PM
sea-crit
Thanks for the input, I'm not sure if higher revs will get me any more MPH but my midrange is awsome with the current setup.
bripar77
5
04-25-2009 05:20 AM
partymedic
04-04-2008 12:56 PM
Toffen
05-21-2005 07:35 AM
bripar77
10-05-2002 06:15 AM
