Borg Warner Oil Change >
Old 05-11-2006 | 03:54 PM
Default Borg Warner Oil Change
I need directions on how to change the trans fluid, and how many times to flush it if some water got inside. Also what does it take to check/change the neutral safety switch on the trans, and what happens when one goes bad can it run with out one?
spk1 is offline
Old 05-12-2006 | 06:09 AM
MOP
Lightbulb Re: Borg Warner Oil Change
One way is to use a small hand pump going through the dip stick hole, I put a few Oz's of dish detergent in the first change and eun it 15-20 at idle shif it into foward & reverse a few times. I do two more changes and check the oil color after a run just in case there is a slight cooler leak.
MOP is offline
Old 05-12-2006 | 02:52 PM
Default Re: Borg Warner Oil Change
Sounds like a plan, thanks for the extra help.
spk1 is offline
THRILLSEEKER
6
03-14-2008 10:30 PM
Beep Beep
Drives and Lower Units
5
05-10-2007 06:14 AM
IRONMAN
1
08-01-2006 10:39 AM
stageharbor
4
07-10-2005 07:47 PM
Horsepower
4
06-12-2004 10:51 AM
