496HO sea water pump pressure monitour??
Does the Merc PCM555 have a sensor to monitour the sea water pressure? If so does it have a fault code for low sea water pressure?
If not where is the best /most convient place to tap in for a pressure gage/transducer to monitour sea water pressure?
Yes, it does have a pressure monitor mounted on the sea water pump, and yes it does go in to gaurdian if press is low
as for tapping for anothe gauge if you have to just T off where the sender is
BillR
11
07-29-2022 06:31 AM
28Eliminator
11
06-22-2004 10:43 PM
