Are there differnt hubs for XR's? >
Old 05-15-2006 | 07:26 AM
BillR's Avatar
OSO Moderator
Default Are there differnt hubs for XR's?
I am trying out a set of Props that came with hub kits.
The hub would only go on my XR propshaft about 7/8 of the way and then stop with a clunk. This left the prop shaft threads just slightly exposed - but obviously was going on right.
I thought the splines wern't aligned, but the hub still wouldn't go all the way on.
The hub kit is in a Merc box and the part #840389K06 for H.D. 1 1/4" prop shaft.
I took the hubs out of my other props so I could run the new props. Except for all the grease, they looked the same.
So, are there different hub inserts for XR drives? My XR's are of 2003 MY.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 05-15-2006 | 10:25 AM
Default Re: Are there differnt hubs for XR's?
I just had that with my fatshaft 300x's. Drove me crazy. I just turned prop a few splines overand eventually the prop just slipped on. The shaft is thicker at the back and is thinner at the prop nut. I think it will work for you too. Don't force it, just keep turning it.
rsess is offline
Old 05-15-2006 | 02:20 PM
throttleup's Avatar
Bill,
It sounds like a "bur" is preventing the propeller from going on all the way.
Julie
throttleup is offline
Ted G
02-10-2007 01:50 PM
sakoutis3
6
06-07-2006 07:03 PM
LostinBoston
16
01-04-2006 03:17 PM
Krumbsnatcher
3
04-15-2004 10:12 PM
enticer
4
07-11-2002 12:12 PM
