oil filter pad adapter >
Old 05-22-2006 | 12:09 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Default oil filter pad adapter
I am thinking about upgrading my 500 hps with larger oil lines and would replace the adapter omn the block that sits where the oil filter ussually does and cppreformance has a nice looking on with the oil line exiting the side versus the bottom this would alos clean up the plumbing a bit
Anyone have a suggestion on these or anothe rmfg.
klaw is offline
Old 05-22-2006 | 05:29 PM
Vinny P's Avatar
I hate the winter!!
Default Re: oil filter pad adapter
I just installed a system from Hardin Marine. I used 3/4" pipe fittings and -12 AN lines. So far, its works great.
Vinny P is offline
Old 05-22-2006 | 06:33 PM
GOODT's Avatar
teage or hardin
GOODT is offline
Old 05-22-2006 | 07:18 PM
RLW
http://www.stefs.com/products/adapters.htm
This is the Stef's adapter I am using on my Dart Big M block.
A quality piece.
RLW is offline
Old 05-22-2006 | 07:42 PM
TC's Avatar
TC
I just just completed the install of a complete Hardin Marine oil system upgrade. I used a thermostatically controlled combo cooler, new filter head and block adapter from them. All parts appear to be of superior quality! The block adapter is actually a piece from Keith Eickert. I will be priming and running the engine tomorrow for the first time this season. Can post pics but my install looks alot like checkmate454mags. Good luck!
TC is offline
Old 05-22-2006 | 07:57 PM
Elite Marine's Avatar
Anyone have the HP500 set up for sale???? I'd like to buy one soon!!
Elite Marine is offline
Old 05-23-2006 | 03:25 AM
articfriends's Avatar
Anythings better than stock merc,just don't buy anything thats cast aluminum vs billet as it will crack and you should use -12 hose and fittings so that your tightest/smallest restriction is at least 1/2 inch,Smitty
articfriends is offline
ezstriper
1
10-13-2008 09:29 PM
Scarab3DMC
2
09-23-2008 11:35 AM
CHAOS REIGNS
Pantera
3
07-08-2007 06:52 AM
klaw
5
04-03-2003 10:50 AM
FindMe
0
01-29-2003 09:44 PM
