superboat transoms >
superboat transoms
superboat transoms
Old 05-29-2006 | 09:12 PM
rch662's Avatar
Default superboat transoms
Hi all, i was just doing some clean up on my 24', when i pulled the caps off the top of the transom to have them powder coated, i was surpised to find the core does'nt appear to be plywood, or is just the top capped off with a resin and something mix ? and are the transoms plywood from there on down ? thanks for any input. Rick
rch662 is offline
Old 05-30-2006 | 06:43 AM
Default Re: superboat transoms
to my knowledge all the transoms are ply with the top glassed and gelled.
z.zuperboat is offline
Old 05-30-2006 | 11:53 AM
SUPERSTITIOUS's Avatar
What Z said.....
SUPERSTITIOUS is offline
Old 05-30-2006 | 07:09 PM
TeamSaris's Avatar
Driver-441
Racer
Originally Posted by OH-ZONE
What Z said.....
yep and VERY strong...
TeamSaris is offline
Old 05-30-2006 | 10:38 PM
rch662's Avatar
nope, not glassed and gelled, maybe somebody did something along the way, it's rough and porous. not really a problem just courious . thanks Rick
rch662 is offline
Old 06-03-2006 | 12:30 PM
FX10's Avatar
The transom and motor well are glass together. The top edge has around a 3/8" hollow, which is filled with a resin/sawdust mixture. The stuff is very strong, much stronger then a cab o sil and resin mixture. Under that, the plywood transom is fully encapsulated with fiberglass. If you see a crack in the filler on the top of the transom, don't worry about it. It's cosmetic, not structural. Squirt a little 5200 in there and put the cap back on.
Rick
FX10 is offline
Old 06-04-2006 | 10:51 PM
rch662's Avatar
thanks Rick, i was'nt sure what that was. anyway, i drilled a few holes in it to find out water made it through the cracks and down inside, any tricks to dry out the water ? or am i in oh no land ? thanks Rick
rch662 is offline
DjMikeyC
Superboat
8
07-25-2007 04:08 PM
TxHawk
11
03-19-2006 10:09 AM
Dregsz
Banana Boat
6
02-20-2006 01:08 PM
nordic95
4
02-08-2006 09:30 PM
Prater
15
01-08-2005 06:39 PM
