Outdrive ID Help >
Outdrive ID Help
Outdrive ID Help
Old 05-31-2006 | 02:49 PM
Prater's Avatar
Default Outdrive ID Help
I am unable to find this drive anywhere. I can not find any numbers on the drive and the prop nut is about 2". It came off an 88 IMP used on the great lakes. They scrapped the boat and said it was a TRS when I purchased it. The gimbal is a speedmaster. Any ideas?
Attached Thumbnails Outdrive ID Help-dcp_2089.jpg   Outdrive ID Help-dcp_2090.jpg
Prater is offline
Old 05-31-2006 | 03:20 PM
Prater's Avatar
Default Re: Outdrive ID Help
I think I may have found it, a Speedmaster III Clubfoot. Is this right?
Prater is offline
Old 05-31-2006 | 03:43 PM
Yes I think you are right. I am pretty sure it`s a Speedmaster III clubfoot.
Found this if it helps: http://www.mercstuff.com/drive_idspeedmaster.htm
Hydrolift is offline
Old 05-31-2006 | 06:46 PM
Superboat Guy's Avatar
I dont think its a speedmaster, its a plain 3. I had a few of those, same upper as a speedmaster 3 but the lower is different as you can see. Uses the same gimble, and trans as the speedmaster. These came with big and small block power in front of them, come to think of it the small blocks used the 71 trans and the big block used the 72. Back in the 1980s I had a pair stolen from me....
Superboat Guy is offline
Old 05-31-2006 | 09:27 PM
bowtie's Avatar
Looks like a TR drive with a broken skeg to me. What size is the boat. They usually put them on big boats without big power. Same upper as a TRS but bigger lower. Prop nut is 1-7/16. Spins a 20" diameter prop.
bowtie is offline
Old 05-31-2006 | 11:04 PM
Prater's Avatar
Bowtie, its not a TR but the skeg is broken.
Prater is offline
Old 05-31-2006 | 11:19 PM
Prater's Avatar
I am clearing house so if anyone is interested in this send me a PM. I have the transom assembly to go with this but no rams.
Prater is offline
Old 06-01-2006 | 06:56 AM
I did a quic search for a pic of a 3 drive. This was all I can come up with.
3 drive
Old 06-01-2006 | 06:52 PM
old style 3 . not a tr or trs
JIMG is offline
littledcsrodshop
03-28-2007 08:39 AM
260
0
08-06-2006 08:58 AM
99fever27
7
05-29-2006 08:01 PM
CHAOS REIGNS
5
12-03-2002 12:48 PM
scarabrick
11-27-2002 12:37 PM
