Go Back  Offshoreonly.com > Owners Forum > Checkmate
Will a 10 Qt Canton Pan fit in a 251 Convincor? >
Old 06-02-2006 | 03:34 PM
Default Will a 10 Qt Canton Pan fit in a 251 Convincor?
Need some help from present or past 251 owners. I'm having a new engine built for my 1991 251 Convincor which will include a 10 Qt Canton pan. The old engine was a 454 Magnum with what I believe was a 6 Qt pan (the engine held 7 qts which included all lines/coolers etc). I'm wondering what kind of pans have been used for larger engines and will this pan fit in my boat? Was hoping someone remembered how much room there was. Thanks
Corbs is offline
Old 06-10-2006 | 04:35 AM
Default Re: Will a 10 Qt Canton Pan fit in a 251 Convincor?
Any help would be appreciated. Thanks
Corbs is offline
Old 06-11-2006 | 06:16 AM
Kelly O's Avatar
Will need to know the dimensions of the Canton pan relative to stock. There is lots of room for additional depth and length of the deep sump, but room for added width would be the concern.
Kelly O is offline
Old 06-13-2006 | 01:41 PM
The pan is 2" deeper than stock, but the same width. I'm pretty sure it will fit, but wanted to check to see what others were using on theirs. Thanks
Corbs is offline
Old 06-13-2006 | 01:57 PM
dyno's Avatar
Charter Member #655
call Tony Groover at Premier Motorsports in Gun lake Michigan if its been done to a check he knows about it...
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 06-13-2006 | 05:59 PM
I have an 89 251 with a 502 and a stock pan that I could measure the clearence if you think we have the same bilge. Might give you some sort of idea. I have the back seat out and it would be easy to crawl in there right now.
Shah Mat is offline
Old 06-14-2006 | 11:54 AM
Shah Mat, if you could I would appreciate it. Otherwise, I'll give Tony a call at Gun Lake. Thanks for the replies.
Corbs is offline
Old 06-14-2006 | 07:35 PM
I can but not for a few days. It's raining right now (boat's covered) and I'm taking my daughter camping tomorrow through the weekend. If Monday isn't too late.
Shah Mat is offline
Old 06-14-2006 | 08:38 PM
Kelly O's Avatar
Two inches additional depth is definitely not a problem. Only issue would be a tall bilge pump that could be relocated if it were an issue.
Kelly O is offline
WHIPLASH
Checkmate
0
06-21-2008 10:54 AM
CHEKT OUT
Checkmate
2
08-07-2007 12:06 PM
scarab39
11
07-03-2006 10:53 AM
Vinny P
Checkmate
7
07-17-2004 10:56 PM
PSDNUT
Checkmate
0
09-10-2002 08:03 PM
