thunder bolt 4 coil >
thunder bolt 4 coil
thunder bolt 4 coil
Old 06-03-2006 | 02:40 PM
Default thunder bolt 4 coil
Is there anything special about the TB4 coil ? Can I replace/ substitute with msd coil and keep my Distributor and module?
tomcei is offline
Old 06-03-2006 | 04:16 PM
Default Re: thunder bolt 4 coil
I replaced mine with MSD and kept the old one on the boat as a spare, just in case.
shawn is offline
Old 06-03-2006 | 05:46 PM
GOODT's Avatar
yes you can replace simple swap out
GOODT is offline
Old 06-03-2006 | 06:18 PM
cool,... I didnt know if mercury had some special incompatable set up.
Thanks,
Tom
tomcei is offline
Old 06-03-2006 | 07:33 PM
Any benefits to the MSD over the TB4? I just bought a boat with slghtly built small blocks and TB4s...Thanks
dave911 is offline
Old 06-03-2006 | 09:03 PM
GOODT's Avatar
the msd has stronger current which translates to better burn
(the simple answer)
GOODT is offline
Old 06-03-2006 | 10:08 PM
MOP
On my 383 I swapped the Tbolt coil that I was told was a 40,000 volt coil for a Jacobs 60,000 volt coil. It looks nice but did little to nothing for performance, 90% of the engines just do not need the extra zap. Tbolt is pretty decent setup don't let anyone BS you.
Phil
MOP is offline
Old 06-05-2006 | 07:03 AM
If you use an MSD coil make sure it is the 'high vibration coil' or it will not last long. The only time a coil change will help performance is if the old one was weak.
Olds Eddie is offline
Old 06-05-2006 | 07:40 AM
vandeano's Avatar
Like my Uncle Melvin use to say "You don't need a forest fire to light a cigarette, when a match will do".
vandeano is offline
Old 06-05-2006 | 10:27 AM
thanks guys, the one I have has physical damage. It works well but I'm not sure if it's working as well as it could.
tomcei is offline
tomcei
5
06-29-2006 09:03 PM
ernie davis
12
06-29-2005 04:19 PM
Sates
2
04-13-2005 01:18 PM
convincor
4
05-12-2003 06:01 PM
dyno
3
01-17-2002 07:13 PM
