KPM Pump question... >
Old 06-06-2006 | 07:49 AM
Mr Gadgets's Avatar
Charter Member #601
Default KPM Pump question...
I just installed my KPM replacement housing.. 2112 and I cant figure out which is the input to the pump.
If you look at the back of the pump it looks like a V with the impeller at the notch of the V. Would the input be the port on the right side?? Without taking the pump apart, I just cant tell..
Any help is appreciated..
Dick
Mr Gadgets is offline
Old 06-06-2006 | 12:43 PM
Orion 27Fever's Avatar
Default Re: KPM Pump question...
The input is on the starboard side or you can use the one that is plugged on the bottom of the housing. I just installed a KPM pump and sea strainer on my boat and I am very pleased with both of them. I had to use the input on the bottom because my sea strainer is mounted on the port side stringer and I just worked better that way.
Brett
Orion 27Fever is offline
Old 06-07-2006 | 05:01 AM
Mr Gadgets's Avatar
Charter Member #601
Orion,
I think my replacement pump is a bit different. The housing only has ports on the back side of it. I rotated the housing to fit my sitution and the impeller is next to the pan and the ports are top and bottom. I will go to work and attemp to post a pic...
Dick
Old 06-07-2006 | 07:03 AM
Mr Gadgets's Avatar
Charter Member #601
Thanks Fred,
I will give Dan a call...
Dick
Old 06-07-2006 | 07:56 AM
Scarab3DMC's Avatar
Dan told me the bottom port is the inlet...I installed two kits...make sure you use lots of pipe dope on the hose connector fittings to the pump...
Scarab3DMC is offline
duksrule
03-05-2007 06:54 PM
blue thunder
6
02-22-2007 04:07 PM
klmken
8
07-06-2006 09:41 PM
SkiDoc
17
05-09-2006 08:38 AM
cigrocket
02-10-2006 06:41 AM
